once I enable your counter, it is writing at full clock speed to the fifo
once the fifo is full, the counter just continues counting
by the time it start reading and printing the first value to the serial port, the fifo is probably already overflowing, as I did print some hello word message. Printing to the serial port is very slow compared to the counter filling up your fifo, and counter counts at something like 50MHz I guess (?)
* once the fifo starts overflowing, not all counter values will go into the fifo, as it is full, and you're only slowly reading the values from the fifo
50 Mhz is the clock speed used by the CPU to process assembler instructions.
Instructions can require multiple clock pulses, this depends also on the cpu type.
You are looking at a way to slow down the loop:
#include <stdio.h>
#include <unistd.h>
int main()
while (1)
printf("Hello from Nios II! \n");
usleep(1000000);
return 0;
Johi.
I have added "usleep(1000000)" but printing speed is slow but i am getting correct answer.
Can u check my FIFO design.
I think the best way to control the flow of counter instead of slowing down the whole system. Probably you use the almost full signal from the FIFO to stop or disable the write signal from the counter. Currently ,the module "block count" always receive data from counter regardless of any condition. Hope this helping you.
Thanks for your response.
I am new to the altera.
How it can done , can you explain me briefly.
Thank you
It's harder in explanation if you design it in schematic. I make it simpler here:
1) Invert almost full signal from FIFO
2) "ANDed" it with the enable of counter
3) Drive output of "ANDed" signal to both of write FIFO and enable of counter. This is to halt the transfer completely.
Did you mean to create own FIFO IP ?
Sorry to ask silly questions. In NIOS, i need to do ??
The method does not involve any NIOS software or C coding. It is done through logic level. You have to modify the circuitry in the schematic and use primitive logic to construct.
Really sorry, i am not able to understand your logic level flow. can you explain in a better way like schematic diagram.
I need your help to complete this process. But Finally, i need to communicate with NIOS. Because through WIZNET i need to communicate with PC.
But Finally, i need to communicate with NIOS. Is it possible with designs building with primitive logic diagrams ? ?
Just checked that the Avalon FIFO memory could not export the "almost full" signal resulting you could not use it as control signal. It is only accessible through IP API or SW control. So, you have to read it from NIOS and then determine the enable signal from PIO. In schematic, connect the "enable" to both counter and write FIFO. Refer to example code for FIFO control in the UG
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug_embedded_ip.pdf, 20.5.2
Thanks for your reply.
Same thing i have followed.
Enable signal given from PIO
connected enable to both counter and write FIFO. In NIOS same data is printing continuously for certain cycles. Please clarify me how to sort it out.
Design as follows
Counter Verilog Code
module Counter(
input clk,
input enable,
input reset,
output reg[31:0] Final_value,
output reg trig
reg[31:0] counter_out;
reg [7:0] temp=0;
reg [31:0] counter_result;
wire temp1;
wire temp2;
always@(posedge clk)
begin
if(reset)
begin
trig<=0;
temp<=0;
counter_out<=0;
end
else if (enable==1'b1)
begin
counter_out<=counter_out+1;
temp<=temp+1;
if(temp==25)
begin
temp<=0;
trig<=~trig;
end
end
assign temp1=trig;
assign temp2=temp1&&clk;
always@(posedge temp2)
if(reset)
counter_result<=0;
else
begin
counter_result<=counter_result+1;
end
always@(posedge trig)
if(reset)
Final_value<=0;
else
begin
Final_value<=counter_result;
end
endmodule
Schematic Design
NIOS CONSOLE, Same data printing For certain cycles.
Have you tried to use and understand the example code and register map given in the FIFO API? What you need to do is
1) Set the almost full threshold using initialization : altera_avalon_fifo_init()
2) Monitor the read status of FIFO : altera_avalon_fifo_read_status() and its status description can be referred to 20.5.1 Software control=> "i_status"
Hi
On-Chip Memory Size is 4096
FIFO Depth : 1024
So, have i have set the
# define ALMOST_EMPTY 1
# define ALMOST_FULL 1000 //FIFO Depth 1024
The ALMOSTEMPTY and ALMOSTFULL printed in the console are correct.
int main()
int result,i=0;
// Reset the FIFO's IRQ History register. *
altera_avalon_fifo_clear_event(FIFO_0_IN_CSR_BASE, ALTERA_AVALON_FIFO_EVENT_ALL);
int code = ALTERA_AVALON_FIFO_OK;
code= altera_avalon_fifo_init(FIFO_0_IN_CSR_BASE, 0x3F,ALMOST_EMPTY,ALMOST_FULL);
IOWR(ENABLE_PIO_BASE, 0, 0x1);
printf("STATUS = %u\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,altera_avalon_fifo_read_status));
while(1)
result=altera_avalon_fifo_read_fifo(FIFO_0_OUT_BASE,FIFO_0_IN_CSR_BASE);
printf("%d\n",result);
return 0;
In NIOS console,
STATUS =16
result: 0
Suggestion Please
I have attached the Nios Screen-shot.
I am getting all data "0"
The fifo status isn't right. You have put the same function into the function argument. Refer to table 206, to read back all of bits, use the following command:
printf("STATUS = %u\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE,altera_avalon_fifo_status_all));
To debug, please put this status command before starting the transfer and after enabling the transfer.
init_input_fifo();
printf("STATUS = %d\n", altera_avalon_fifo_read_status(FIFO_0_IN_CSR_BASE, altera_avalon_fifo_status_all));
level=altera_avalon_fifo_read_level(FIFO_0_IN_CSR_BASE);
printf("\nLevel=%u\n",level);
if(level !=0)
for(i=0;i<=500;i++)
//result[i]=IORD_ALTERA_AVALON_FIFO_DATA(FIFO_0_OUT_BASE);
data[i]=altera_avalon_fifo_read_fifo(FIFO_0_OUT_BASE, FIFO_0_IN_CSR_BASE);
printf("data=%lu\t",data[i]);
printf("\n Full=%d\n", altera_avalon_fifo_read_almostfull(FIFO_0_IN_CSR_BASE));
printf("Empty=%d\n",altera_avalon_fifo_read_almostempty(FIFO_0_IN_CSR_BASE));
Now my code is right.
