17252 Discussions
FIFO Simulation Model Quartus Prime Lite
ChristofAbt
Good morning,
I am designing an interface between an ADC and a microcontroller. I want to use a MAX10 device. At the moment I am using Quartus Prime Lite Edition Version 23.1 The core of the interface are some FIFO memories. I can generate the FIFOs with the IP catalog. The generated FIFO contains a component scfifo. I cannot find this component anywhere. Therefore I get the message "Component instance "scfifo_component : scfifo" is not bound."
I've read that there is the option "Generate Simulation Model". I cannot find this option in the Quartus Prime Lite edition. My own VHDL code can be synthesized and simulated quite well. Is it necessary to buy the Quartus Standard Edition?
Thanks for your help
Best regards Christof
ShengN_Intel
I try to simulate the fifo without any problem check screenshot (send to your personal email).
May be can try with Quartus Standard evaluation mode any problem?
Sheng
ShengN_Intel
Any update or concern?
Sheng
