i would like to transmit the output of ASUS Xtion Pro via wi-fi and i want to use FPGA to implement this. is it feasible?
--- Quote Start --- i would like to transmit the output of ASUS Xtion Pro via wi-fi and i want to use FPGA to implement this. is it feasible? --- Quote End --- FPGA are suitable platforms for very complex tx/Rx baseband processing modules such as mapping/interleaving/fft/filtering/upsampling. You will need to add the DAC and RF design till antenna separately.
