17267 Discussions
FPGA Programming by Command Line
Sulaiman
I have finished project implemented in Standard Quartus18.1 for MAX10 device. The final bitstream is encrypted. Currently, I use Quartus Programmer GUI, to program each device. However, I would like to implement command line tool which program fpga automatically.
In Programmer GUI, I am merging ekp together with pof file (by right clicking on the pof file and selecting add ekp file). How can I do this by command line?
Sulaiman
NurAiman_M_Intel
Thank you for contacting Intel community.
Per my understanding, you would like to use command line to program FPGA? If yes, kindly refer to Intel MAX 10 configuration user guide below:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Aiman
Sulaiman
Yes I would like to use command line to program FPGA but with encrypted pof.
I can not find it in pdf file. Can you determine the page number?
Sulaiman
ak6dn
Valued Contributor III
I use the 'make' system to run a command line compilation of a design using Quartus.
Here is my Makefile:
DESIGN=DE0_PDP8
all:: generate report
generate::
	$(QUARTUS_BIN)/quartus_map $(DESIGN) --write_settings_files=off
	$(QUARTUS_BIN)/quartus_fit $(DESIGN) --write_settings_files=off --seed=1
	$(QUARTUS_BIN)/quartus_asm $(DESIGN) --write_settings_files=off
	$(QUARTUS_BIN)/quartus_sta $(DESIGN)
	$(QUARTUS_BIN)/quartus_sta -t generate_timing.tcl $(DESIGN) 10
	$(QUARTUS_BIN)/quartus_eda $(DESIGN) --write_settings_files=off -c $(DESIGN)
	$(QUARTUS_BIN)/quartus_cpf -c $(DESIGN).cof
report::
	@-echo ' '
	-egrep --color -i '\([0-9]+ violated\)' TQ_*.rpt
	@-echo ' '
	-egrep -vi '^this panel reports' TQ_fmax_summary.rpt
	@-echo ' '
clean::
	-rm -f $(DESIGN).*.rpt $(DESIGN).*.summary $(DESIGN).*.smsg $(DESIGN).map
	-rm -f $(DESIGN)_assignment_defaults.qdf TQ_*.rpt PLL*.txt meminit.txt
	-rm -f $(DESIGN).done $(DESIGN).map $(DESIGN).pof $(DESIGN).sof $(DESIGN).jic
	-rm -f $(DESIGN).pin $(DESIGN).jdi $(DESIGN).qws $(DESIGN).*.ddb $(DESIGN).sld
	-rm -rf db incremental_db simulation
# the end
To setup the Quartus environment (I use multiple versions, this sets up 16.0) I first run this shell script:
#!/bin/bash
export QUARTUS_BASE=/cygdrive/C/Tools/Altera/16.0
export QUARTUS_ROOTDIR=${QUARTUS_BASE}/quartus
if [ -e ${QUARTUS_BASE}/quartus/bin64 ] ; then
  export QUARTUS_BIN=${QUARTUS_BASE}/quartus/bin64
else
fi
export QSYS_ROOTDIR=${QUARTUS_BASE}/quartus/sopc_builder/bin
export SOPC_KIT_NIOS2=${QUARTUS_BASE}/nios2eds
echo QUARTUS_BASE=${QUARTUS_BASE}
echo QUARTUS_ROOTDIR=${QUARTUS_ROOTDIR}
echo QUARTUS_BIN=${QUARTUS_BIN}
echo QSYS_ROOTDIR=${QSYS_ROOTDIR}
echo SOPC_KIT_NIOS2=${SOPC_KIT_NIOS2}
# the end
Then in the design directory I just type 'make' and wait for it to finish. No GUI needed. I run under CYGWIN unix environment on Win10 64b.
Sulaiman
I am using the following command to program FPGA:
quartus_pgm -m JTAG -o p;design.pof
When we want to program encrypted pof, we have 2 files(.ekp, .pof). We can program them together or separately.  These methods are found in "Intel® MAX® 10 FPGA Configuration User Guide" document at page 51 but by GUI.
Can I do one of these methods by quartus_pgm commands.
Sulaiman
NurAiman_M_Intel
Apologize for the delay in response as I did not received the notification.
Have you try the method suggested by our friend below:
ak6dn
Re: Re:FPGA Programming by Command Line
Message Body
DESIGN=DE0_PDP8
generate::
report::
 @-echo ' '
 @-echo ' '
 @-echo ' '
clean::
# the end
#!/bin/bash
else
fi
# the end
Post TimeApr 24, 2021 5:34:22 PM
Let me know if it is succesful or not.
Aiman
Sulaiman
I didn't do the method from our friend. I think this method for generating the programming files.
My question is explained below:
Can I do one of these methods by quartus_pgm commands or other command.
Sulaiman
NurAiman_M_Intel
You can use quartus_pgm command to program pofbut not ekp. Please see below link:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/tclscriptrefmnl.pdf (page 76-79)
Aiman
Sulaiman
I understand from you, we can only program encrypted pof using GUI programmer!
Sulaiman
NurAiman_M_Intel
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
