FPGA SDRAM DE10-standard
gazel
When I was writing nios in exlipse, I got an error that there was not enough space, so I decided to implement SDRAM.
How can I implement SDRAM in DE10Standard?
I am using QuartusPrime17.1, DE10-standard(5CSXFC6D6F31C6).
AdzimZM_Intel
Hi Sir,
I'm not clear on what is your objective.
Do you try to use internal memory but the space is not enough?
What do you mean by the 'not enough space' there?
Adzim
AdzimZM_Intel
Hi Sir,
Adzim
Caster
Any advice where to buy 30 pieces 5CSXFC6D6F31C6
AdzimZM_Intel
Hi Sir,
You can contact with the Intel Distributors or Approved Supplier for purchasing the product.
You can find them in this link.
Please make sure that you contact with your local supplier because they have some coverage of the countries.
Adzim
AdzimZM_Intel
Hi Sir,
Do you have any update on this topic?
Adzim
Caster
Unfortunately not. The 5CSXFC6D6F31C6 are not available nowhere.
AdzimZM_Intel
Hi Sir,
I'm sorry to say that there not much I can help you in this area.
Probably the Distributor and Supplier are the main support for the product availability.
Adzim
