Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Fatal ERROR on Quartus II
i'm having a problem when a try to compile some vhdl codes in Quartus, Someone here knows how to fix it?
The message that i see when i try is:
*** Fatal Error: Access Violation at 0X000007FED0F2802F
Module: quartus_map.exe
Lock in use: 54
Stack Trace:
0x20802e: VRFX_ELABORATOR::operator= + 0x4b94e
0x21982d: VRFX_ELABORATOR::operator= + 0x5d14d
0x214182: VRFX_ELABORATOR::operator= + 0x57aa2
0x2143c1: VRFX_ELABORATOR::operator= + 0x57ce1
0x221acb: VRFX_ELABORATOR::operator= + 0x653eb
0x21c470: VRFX_ELABORATOR::operator= + 0x5fd90
0x2265c3: VRFX_ELABORATOR::operator= + 0x69ee3
0x22209f: VRFX_ELABORATOR::operator= + 0x659bf
0x18c1cf: VRFX_ELABORATOR::elaborate + 0x13281f
0x190418: VRFX_ELABORATOR::elaborate + 0x136a68
0x190b2c: VRFX_ELABORATOR::elaborate + 0x13717c
0x605b6: VRFX_ELABORATOR::elaborate + 0x6c06
0x59b9c: VRFX_ELABORATOR::elaborate + 0x1ec
0xc50b3: sgn_clear_check_ip_functor + 0x3aeb3
0xc8d7f: sgn_clear_check_ip_functor + 0x3eb7f
0xca666: sgn_clear_check_ip_functor + 0x40466
0x92834: sgn_clear_check_ip_functor + 0x8634
0xa37fc: sgn_clear_check_ip_functor + 0x195fc
0xa01ba: sgn_clear_check_ip_functor + 0x15fba
0xa384c: sgn_clear_check_ip_functor + 0x1964c
0xa79ee: sgn_clear_check_ip_functor + 0x1d7ee
0x10cc2: sgn_qic_full + 0x152
0x11fad: qexe_get_command_line + 0x1b7d
0x14e0e: qexe_process_cmdline_arguments + 0x59e
0x14f21: qexe_standard_main + 0xa1
0x4c78: msg_exe_fini + 0x58
0x53bc: msg_exe_fini + 0x79c
0x1584: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0x5f9f: msg_exe_main + 0x8f
0x159cc: BaseThreadInitThunk + 0xc
0x2a560: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.0.1 Build 232 06/12/2013 SJ Web Edition
Service Pack Installed: 1
Try deleting the db/ and incremental_db/ folders
if that doesnt work, then you'll need to raise a ticket via mysupport
