17125 Discussions
Fatal Error: Access Violation at 0X00007FFCA1DCA69C
Mitsuo3314
When I installed and used Quartus Prime ver18.1, it occurred in "Analysis & Synthesis".
Please tell me how to resolve this error.
I am using 18.1 to match the environment with the existing project.
The contents of the error file are as follows.
Problem Details
Error:
*** Fatal Error: Access Violation at 0X00007FFCA1DCA69C
Module: quartus_map.exe
Stack Trace:
    0x1a69b: HDB_SOURCE_FILE::get_library + 0x3 (DB_HDB)
    0x6744c: SGN_QIC_UTILS::create_new_hierarchy_info + 0xe8c (synth_sgn)
    0xb75ae: SGN_EXTRACTOR::recursive_extraction + 0x28e (synth_sgn)
    0xb6e6f: SGN_EXTRACTOR::recurse_into_newly_extracted_netlist + 0x36f (synth_sgn)
    0xb757b: SGN_EXTRACTOR::recursive_extraction + 0x25b (synth_sgn)
    0xb08c3: SGN_EXTRACTOR::extract + 0x1d3 (synth_sgn)
    0x1324e: sgn_qic_full + 0x19e (synth_sgn)
     0x4351: qsyn_execute_sgn + 0x131 (quartus_map)
    0x13f9c: QSYN_FRAMEWORK::execute_core + 0x12c (quartus_map)
    0x13aa6: QSYN_FRAMEWORK::execute + 0x496 (quartus_map)
    0x112bc: qexe_do_normal + 0x1ec (comp_qexe)
    0x16142: qexe_run + 0x432 (comp_qexe)
    0x16e51: qexe_standard_main + 0xc1 (comp_qexe)
    0x1b08b: qsyn_main + 0x51b (quartus_map)
    0x12e98: msg_main_thread + 0x18 (CCL_MSG)
    0x1467e: msg_thread_wrapper + 0x6e (CCL_MSG)
    0x16660: mem_thread_wrapper + 0x70 (ccl_mem)
    0x12761: msg_exe_main + 0xa1 (CCL_MSG)
    0x29872: __tmainCRTStartup + 0x10e (quartus_map)
    0x17033: BaseThreadInitThunk + 0x13 (KERNEL32)
    0x52650: RtlUserThreadStart + 0x20 (ntdll)
End-trace
Executable: quartus_map
Comment:
None
System Information
Platform: windows64
OS name: Windows 10
OS version: 10.0
Quartus Prime Information
Address bits: 64
SyafieqS
Hi Mitsuo,
Can you attach a small test design here .qar for me to replicate the issue.
This might be a valid bug.
Mitsuo3314
Hi SyafieqS.
Thank you for your reply.
I attached .qar file.
This qar file is similar to the hdmi sample.
Add one piece of information.
I moved it on another PC, and this Fatal did not occur.
Next, I moved it to another folder and checked it, and this Fatal did not occur.
Therefore, it is considered that the problem depends on the corresponding folder,
and I think this problem is solved.
Mitsuo
SyafieqS
Mitsuo,
Thank you for the file..
Let me know if the workaround not feasible for you as by changing the folder or machine as you mentioned.
SyafieqS
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution and give Kudos.
