17008 Discussions
Fatal Error: RUNTIME_0033 altera_mf.vhd (14081) Negative waveform time expression
Karthi_S
Does anyone experienced the following fatal error in altera + aldec environment?
KS
Kenny_Tan
Which version of  Aldec Riviera-PRO Simulator and Quartus version that you were using?
This might be the case both version are not compatible.
Karthi_S
I am using Active-HDL-10.4a and Quartus Prime 17.0 Standard Edition.
Kenny_Tan
In that case, you may have to downgrade the version of your Active HDL 10.3. Also Active HDL support for windows only.
You will also need to upgrade to Quartus Prime 18.1 Standard Edition.
Check on https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/rn/rn-qts-std-dev-support.pdf page 7
