17263 Discussions
Fatal error on quartus ||
Hello everybody,
today i was testing my code and when i compile it the program gives me this error:
*** Fatal Error: Access Violation at 0X00007FFDF4F788BB
Module: quartus_map.exe
Stack Trace:
0xa88ba: VRFX_ELABORATOR::elaborate + 0x4f1aa
0xab0e5: VRFX_ELABORATOR::elaborate + 0x519d5
0x190222: VRFX_ELABORATOR::operator= + 0x80932
0x1908bc: VRFX_ELABORATOR::operator= + 0x80fcc
0x60316: VRFX_ELABORATOR::elaborate + 0x6c06
0x598fc: VRFX_ELABORATOR::elaborate + 0x1ec
0xd6f93: sgn_clear_check_ip_functor + 0x3a323
0xdac3f: sgn_clear_check_ip_functor + 0x3dfcf
0xdc525: sgn_clear_check_ip_functor + 0x3f8b5
0xa57d4: sgn_clear_check_ip_functor + 0x8b64
0xb5efc: sgn_clear_check_ip_functor + 0x1928c
0xb286a: sgn_clear_check_ip_functor + 0x15bfa
0xb5f4c: sgn_clear_check_ip_functor + 0x192dc
0xba0dd: sgn_clear_check_ip_functor + 0x1d46d
0x10de2: sgn_qic_full + 0x152
0x128ed: qexe_get_command_line + 0x206d
0x1573e: qexe_process_cmdline_arguments + 0x59e
0x15851: qexe_standard_main + 0xa1
0xa7f8: msg_exe_fini + 0x58
0xaf3c: msg_exe_fini + 0x79c
0x1f14: MEM_SEGMENT_INTERNAL::~MEM_SEGMENT_INTERNAL + 0x194
0xb8bf: msg_exe_main + 0x8f
0x13033: BaseThreadInitThunk + 0x13
0x71550: RtlUserThreadStart + 0x20
End-trace
Quartus II 64-Bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition
can someone help me understand what this is? and also how to solve this problem? thank you for your answer. :(:(
Try by deleting the "db" and "incremental_db" folders from created project stored directory & If that doesn`t work then you'll have to file a service request at,
http://mysupport.altera.com (http://mysupport.altera.com/
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation
