The error shown is-
The following is the error shown
** Fatal: (vsim-3807) Types do not match between component and entity for port "dataout".
# Time: 0 ps Iteration: 0 Instance: /lineartau_1_vhd_vec_tst/i1 File: lineartau_1.vho Line: 86
# FATAL ERROR while loading design
# Error loading design
The code is-
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity lineartau_1 is
port (clk:IN std_logic;
dataout:OUT integer range -128 to 127);
end lineartau_1;
architecture arch_sine of lineartau_1 is
signal i:integer range 0 to 31:=0;
type memory_type is array (0 to 31) of integer range -128 to 127;
signal sin:memory_type:=(50,60,69,78,85,92,96,99,100,99,96,92,85,78,69,
60,50,40,31,22,15,8,4,1,0,1,4,8,15,22,31,40);
begin
process(clk)
begin
if rising_edge(clk)
then
dataout<=sin(i);
i<=i+1;
if(i=31)
then
i<=0;
end if;
end if;
end process;
end arch_sine;
The testbench created by Altera-Modelsim is-
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY lineartau_1_vhd_vec_tst IS
END lineartau_1_vhd_vec_tst;
ARCHITECTURE lineartau_1_arch OF lineartau_1_vhd_vec_tst IS
-- constants
-- signals
SIGNAL clk : STD_LOGIC;
SIGNAL dataout : STD_LOGIC_VECTOR(7 DOWNTO 0);
COMPONENT lineartau_1
PORT (
clk : IN STD_LOGIC;
dataout : OUT STD_LOGIC_VECTOR(7 DOWNTO 0)
END COMPONENT;
BEGIN
i1 : lineartau_1
PORT MAP (
-- list connections between master ports and signals
clk => clk,
dataout => dataout
-- clk
t_prcs_clk: PROCESS
BEGIN
LOOP
clk <= '0';
WAIT FOR 500000 ps;
clk <= '1';
WAIT FOR 500000 ps;
IF (NOW >= 50000000 ps) THEN WAIT; END IF;
END LOOP;
END PROCESS t_prcs_clk;
END lineartau_1_arch;
I have defined dataout as an integer but still the testbench is defining it as a std_logic_vector.
Please help resolve this problem
Where is the testbench coming from? Just edit it to change dataout to an integer type.
Test bench is generated using "Start Test Bench Template Writer" and its template so in this case it needs to be edited like below,
SIGNAL dataout : integer range -128 to 127; -- at signals
dataout : OUT integer range -128 to 127 --- at COMPONENT lineartau_1
Let me know if this has helped resolve the issue you are facing or if you need any further assistance.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
Are you able to do simulation?
Best Regards
Vikas Jathar
