Community
cancel
Showing results for
Search instead for
Did you mean:
Honored Contributor I
Fitter can't place 1 fractional PLL
we have a Cyclone V SX design that fails to compile because the fitter can't place 1 fractional PLL. I have compiled the design succesfully previously, but after I added two 2-lane HiSPi (LVDS) inputs to design the fitter fails. It seems that the LVDS I/O-banks (5A, 5B ) doesn't have enough PLLs since two PLLs are needed for the LVDS_RX-blocks. Has anybody any ideas how to solve this issue?
Any help appreciated.
Joonas
Hi Joonas,
maybe you use just one LVDS_RX block with two channels or the "Use External PLL" option to share one PLL between the LVDS_RXs and other clocks.
regards
Jens
--- Quote Start ---
Hi Joonas,
regards
Jens
--- Quote End ---
I guess that we cannot share the PLL between the LVDS-inputs since the the LVDS-clocks come from two seperate image sensors that aren't syncronized between each other. Actually we have four image sensors so we would need four different PLLs and four different LVDS_RX-blocks. I'm not sure if this is possible with Cyclone V-device.
