17043 Discussions
For loop, array and a step motor, VHDL
I'm trying to implement a sequence in order to use a step motor using VHDL. Since I'm really new to VHDL I can't see what's missing in my code. I want to loop through an array to give the different steps to my variable named motor.
I'd appreciate any help.
library IEEE; use IEEE.STD_LOGIC_1164.ALL; entity main is Port ( motor : out STD_LOGIC_VECTOR (3 downto 0)); end main; architecture Behavioral of main is type my_array is array (0 to 6) of std_logic_vector(2 downto 0); signal secuencia : my_array; secuencia := ("0000", "0001", "0010", "0011", "0100", "0101", "0110", "0111"); begin variable i : std_logic:= '1'; for i in secuencia' range loop motor <= secuencia(i); end loop; end Behavioral;
These are the errors:
ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 12: Syntax error near "secuencia". ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 15: Syntax error near ":=". ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 16: Syntax error near "loop". ERROR:HDLCompiler:806 - "C:/Users/main.vhd" Line 18: Syntax error near "loop". ERROR:ProjectMgmt:496 - 4 error(s) found while parsing design hierarchy.
Looking the code it seems you are a C programmer. The for loop statement in vhdl it's different from the for sentence of C. For loop is not a sequential statement. It is used when you need to copy paste many times a circuit cell ( iterative circuit ).
Probably you're tried to explore the 8 output value you write in secuencia. A counter may solve it:
signal sec_reg, sec_next : unsigned(2 downto 0);
begin
process( clr_n, clk )
begin
if( clr_n = '0' ) then
sec_reg <= ( others => '0' );
sal_reg <= "0000";
elsif( clk'event and clk = '1 ) then
sec_reg <= sec_next;
sal_next <= sal_next;
end if;
end process;
sec_next <= sec_reg + 1;
motor <= sal_reg;
process(sec_reg)
begin
case sec_reg is
when "0000" =>
sal_next <= "0000";
when "0001" =>
sal_next <= "0001";
-- complete the rest
end case;
end process;
end Behavioral;
There something missing in this code. To drive a stepper motor you need to slow down the clock.
Hey! Thank you so much for your answer. Actually I'm more into C so finally I decided to use a PIC. Anyways, I am going to try it again using VHDL.
Here is what I was trying to do:
char values = {0B01000, 0B01100, 0B00100, 0B00110, 0B00010, 0B00011, 0B00001, 0B01001}; void motor(){ short i; for (i = 0; i<7; i++){ PORTC= values; Delay_ms(1); } }
Thanks again for your time!! :)
--- Quote Start ---
--- Quote End ---
Sorry to be a pedant, but a for loop IS a sequential statement. It will work exactly like it's C counterpart in the right situations - but only in simulation. The Synthesisor will unroll the loop and create parrallel logic as you describe, but the behaviour of a for loop can be important in testbenches. If you want "sequential" code inside a for loop, you can use a variable instead of a signal updating between iterations (but then you'll get a long chain of logic).
look I developed this code for a stepper motor with a sequence and I hope you serve :)
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_arith.all;
entity mtrpas is
port(
clock,reset:in std_logic;
clkout:inout std_logic;
push_l ,push_r: in std_logic;
pasos2: out std_logic_vector(3 downto 0);
pasos: out std_logic_vector(3 downto 0));
end mtrpas;
architecture archi_mtrpas of mtrpas is
CONSTANT max: INTEGER := 50000000;
CONSTANT half: INTEGER := max/10;
SIGNAL count: INTEGER RANGE 0 TO half;
begin
PROCESS
BEGIN
WAIT UNTIL clock'EVENT and clock= '1';
IF (count < max) THEN
count <= count + 1;
ELSE
count <= 0;
END IF;
IF (count < half)THEN
clkout <= '0';
ELSE
clkout <= '1';
END IF;
END PROCESS;
process(push_l ,push_r,reset,clkout)
variable cuenta: integer range 0 to 5:=0;
begin
if clkout'event and clkout='1' then
if(reset='0') then
cuenta:=0;
else
if(push_l='1') then
cuenta:=cuenta+1;
if(cuenta=5) then
cuenta:=0;
end if;
end if;
if(push_r='1') then
cuenta:=cuenta-1;
if(cuenta=0) then
cuenta:=4;
end if;
end if;
end if;
end if;
case cuenta is
when 0=> pasos<="0000";pasos2<="0000";
when 1=> pasos<="1000";pasos2<="1000";
when 2=> pasos<="0100";pasos2<="0100";
when 3=> pasos<="0010";pasos2<="0010";
when 4=> pasos<="0001";pasos2<="0001";
when others => null;
end case;
end process;
end archi_mtrpas;
Can you give an example?:
--- Quote Start ---
--- Quote End ---
