Frequency Counter Error
PonPon
I'm not familiar with FPGA.
I want to build a frequency counter, and below is my RTL code:
module Edge_counter(
input fin,
input clk,
input rst_n,
output reg [15:0] cnt_out
assign gate_n = ~gate;
////sub module////
edge_detector edge_detector(
    .clk(clk),
.rst_n(rst_n),
    .pulse(fin),
    .pos_edge(pos_edge),
gate gate1(
.clock(clk),
.rst_n(rst_n),
.gate(gate)
memory_store memory_store1(
.clock(gate_n),
.rst_n(rst_n),
.signal_in(cnt_out)
////code////
always @(posedge clk or negedge rst_n)begin
if(!rst_n)
cnt_out <= 0;
else if(gate == 1'b1 && pos_edge == 1'b1)                      //gate 1, pos_edge 1
cnt_out <= cnt_out + 1'b1;
else if(gate == 1'b1 && pos_edge == 1'b0)                      //gate 1, pos_edge 0
cnt_out <= cnt_out;
else if(gate == 1'b0)
cnt_out <= 0;
end
endmodule
The gate time is 1ms. (0.5ms gate = 1, and 0.5ms gate = 0)
And I use Function Generator to output a FM square wave, the carrier frequency is 60kHz, modulation frequency is 50Hz, and the frequency deviation is 10kHz.
The experiment result looks like this:
I don't think the output value = 29 or 31 is correct, but I have no idea why have these values.
Will the problem comes from Timing analysis? Because I don't know how to correctly constrain all the signal in my design.
TingJiangT_Intel
Won't the FM square wave you are using have value between 50khz ~ 70khz?
TingJiangT_Intel
 As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
