As the title says, modelsim reported a lot of timing violations during the gate-level simulation. However the same design passed STA. I used the same clk frequency in the simulation as in the timing constraint, I also tried slower frequency in the simulation and that generated even more timing violations. How did that happen? How should I deal with it? Thanks!Link Copied
Timing violations can be e.g. caused by unconstrained external signals or asynchronous logic that isn't covered by timing constraints. You should analyze the nature of the timing violations.
Thanks for the reply.
Turns out the violations were due to unconstrained i/o paths. The violations disappeared when I added constraints with random parameters. Could you advice me how to determine input/output delay for specified demo board? I'm currently implementing a NIOS system on a Terasic de4 board. Is there any document I can take reference from?
