17049 Discussions
Generate a Test bench Output files .Vht
Hello
I use recently Quartus II 13.1
I would like generate a Test bench Output files .Vht from Waveform/vector File .VWf but I was unsuccessful .The file .vwf is a separate window from Quartus .
Before, I use Quartus II 7.2 and for to do that I generate a Waveform/vector File .VWf and from menu I click on the File => Export ,then it’s generate and open a Test bench Output files .Vht .
Could you tell me how I can generate a vht from vwf file fom quartus II 13.1? Thant you .
Under Simulation menu, select "Generate ModelSim Testbench and script".
Thank a lot Siraj Muhammad
I have now another problem!
When I do Generate modelsim Testbennh and script from Quartus 13.1, It generate verilog HDL file .
Here’s how I do.
I set the format output VHD from : settings=>EDA Tool Settings=>simulations=>EDA Netlist Writer Settings and after Apply.
After I generate the waveform/vector File and as you told me, Under Simulation menu, select "Generate ModelSim Testbench and script". But, It generate verilog HDL file. When I return at the settings page I surprise to see that quartus change the format, it put Verilog HDL!
Could you describe the different Steps for get the Format output Vht and not Vt. Thank you again
--- Quote Start ---
Here’s how I do.
--- Quote End ---
Actually I don't have any idea about that, I have just moved to ModelSim because I found so many problems with the Waveform Simulator. Plus, there are many features that will benefit you. I recommend using ModelSim and learning how to write testbench.
