Hello all,
I am trying to implement an eight bit carry look ahead adder. But my main issue is that I do not know how to output the sum which is an 8-bit out std_logic vector to a seven segment display. As per this youtube video (https://www.youtube.com/watch?v=vkkgyoc4zra), I was able to implement the 8 bit to bcd circuit (component binbcd in my code) and through this link (http://vhdlguru.blogspot.com/2010/03/vhdl-code-for-bcd-to-7-segment-display.html) I am able to output the bcd on the seven segment display (called printOut in my code). However I don't know how to fully integrate every thing in my code. I was thinking that I could declare a signal called output and set the value of sum to output by doing output <= sum. But then I get the errorError (10309): VHDL Interface Declaration error in cla4_add_subtract.vhd(51): interface object "sum" of mode out cannot be read. Change object mode to buffer.
How do I go about reading from the sum or better yet how do I output 8 bit std_logic_vector to 7 segment display? library IEEE;
use IEEE.std_logic_1164.all;
entity cla4_add_subtract is
port(a, b: in std_logic_vector(7 downto 0);
cin: in std_logic;
subtract: in std_logic;
sum: out std_logic_vector(7 downto 0);
cout: out std_logic;
overflow: out std_logic);
end cla4_add_subtract;
architecture cla4_add_subtract_arch of cla4_add_subtract is
component mux2to1
port(
sel: in std_logic;
y: out std_logic_vector(7 downto 0));
end component;
component claFour
port( a, b: in std_logic_vector(7 downto 0);
carryin: in std_logic;
cgout, cpout, overflow: out std_logic);
end component;
component binbcd
port(bin : std_logic_vector(7 downto 0);
p: out std_logic_vector(9 downto 0));
end component;
component printOut
port(digit: in std_logic_vector(3 downto 0);
print: out std_logic_vector(6 downto 0));
end component;
signal carry: std_logic;
signal b_not: std_logic_vector(7 downto 0);
signal b_actual: std_logic_vector(7 downto 0);
begin
b_not <= not b;
carry <= cin;
MUX_SUB:
mux2to1
port map (b, b_not, subtract, b_actual);
ADD0:
claFour
port map (a, b_actual, carry, sum, cout, open, overflow);
library IEEE;
entity printOut is
port(digit:in std_logic_vector(3 downto 0);
print:out std_logic_vector(6 downto 0));
end printOut;
architecture parch of printOut is
begin
process(digit)
begin
case digit is
when "0000"=> print <="0000001"; -- '0'
when "0001"=> print <="1001111"; -- '1'
when "0010"=> print <="0010010"; -- '2'
when "0011"=> print <="0000110"; -- '3'
when "0100"=> print <="1001100"; -- '4'
when "0101"=> print <="0100100"; -- '5'
when "0110"=> print <="0100000"; -- '6'
when "0111"=> print <="0001111"; -- '7'
when "1000"=> print <="0000000"; -- '8'
when "1001"=> print <="0000100"; -- '9'
when others=> print <="1111111";
end case;
end process;
end parch;
you have an internal signal called something like "sim_i", that connects to sum and read into this new output.
You could also switch the compiler to VHDL 2008 and your original code will work just fine.- Mark as New
--- Quote Start --- you have an internal signal called something like "sim_i", that connects to sum and read into this new output. You could also switch the compiler to VHDL 2008 and your original code will work just fine. --- Quote End --- Syntactically, How would I connect a "sim_i" to sum?
remplace all instances of sum with sum_i in your current code and add:
sum <= sum_i;- Mark as New
Thanks this helped.
