16597 Discussions
HELP - Hardware register
Hello :)
I have created a register, but I am not able to make it work with every clock cycle.
It works good with the reset, but with the clock it automatically enters to the "others" option
Any hints?
library IEEE; use IEEE.std_logic_1164.all; use IEEE.std_logic_arith.all; use IEEE.std_logic_unsigned.all; entity registro_desp is PORT (entradax: in std_logic_vector (7 downto 0); salida: out std_logic_vector (14 downto 0); contador : in std_logic_vector (3 downto 0); clk: in std_logic; reset: in std_logic ); end registro_desp; architecture Behavioral of registro_desp is signal Q: std_logic_vector(14 downto 0); begin reg_desp: process (clk, reset) begin if (reset ='0' and clk = '1' and clk'event) then CASE contador is when "0001" => Q <= ('0' & entradax & "000000"); when "0010" => Q <= ('0' & entradax & "000000"); when "0011" => Q <= ("00" & entradax & "00000"); when "0100" => Q <= ("00" & entradax & "00000"); when "0101" => Q <= ("000" & entradax & "0000"); when "0110" => Q <= ("000" & entradax & "0000"); when "0111" => Q <= ("0000" & entradax & "000"); when "1000" => Q <= ("0000" & entradax & "000"); when "1001" => Q <= ("00000" & entradax & "00"); when "1010" => Q <= ("00000" & entradax & "00"); when "1011" => Q <= ("000000" & entradax & "0"); when "1100" => Q <= ("000000" & entradax & "0"); when "1101" => Q <= ("0000000" & entradax); when "1110" => Q <= ("0000000" & entradax); when others => Q <= (entradax & "0000000"); --wait until CLK'EVENT and CLK = '1'; --I THOUGHT THAT THIS WOULD WORK, BUT IT DIDN'T :( END CASE; elsif reset='1' then Q<="000000000000000"; salida<=Q; end if; end process; end Behavioral;
Then I suspect that contador is anything other than the values in the case statement. Is it "0000", "1111" or "UUUU" or "XXXX" or "100X"?
Where is it not working? What controls contador?
--- Quote Start ---
--- Quote End ---
ok, I realized with your comment that the problem was, in fact, with "contador". I already solved it and it works well.
Sorry for the inconvenience, and thank you a lot :)
