15880 Discussions
HPS change from Quartus II 19.1 to 21.1
PWeis4
we upgraded our Quartus II Software from V19.1 to Version 21.1.
We ran a full compilation without any changes of our design files. Everything works fine, except this warning:
 Warning (11713): The configuration of the Hard Processor Subsystem (HPS) within this design has changed.
The Preloader software that initializes the HPS requires an update.
Using hps_isw_handoff/system_hps_0/, run the Preloader Support Package Generator to update your Preloader software
Do we really have to update the preloader? If yes, why? What is the change in the configuration of the HPS?
Thanks in advance,
Patrick
aikeu
Hi PWeis4,
I think you can find some of the release details under
<installation directory>/quartus/readme.txt
As of the documents of each releases, refer to the below links:
Quartus prime pro:
https://www.intel.com/content/www/us/en/docs/programmable/683706/21-1/introduction.html
Quartus prime standard:
https://www.intel.com/content/www/us/en/docs/programmable/683593/21-1/version-software-and-device-su...
Aik Eu
sstrell
There are always changes/improvements from version to version.  Since it's just a warning, you don't have to regenerate the preloader.
aikeu
Hi PWeis4,
I will close this thread if no further question.
Aik Eu
PWeis4
thank you for the answer.
Just one more question:
Is there a change log ore something, where we can check what changes were made?
Patrick
aikeu
Hi PWeis4,
Quartus prime pro:
Aik Eu
PWeis4
I will check the documents for changes in HPS.
Thank you,
Patrick
aikeu
Hi PWeis4,
I will close this thread for now.
Do consider open a new thread if there is further question.
Aik Eu
