Info: Subscription Agreement, the Intel Quartus Prime License Agreement,
Info: the Intel FPGA IP License Agreement, or other applicable license
Info: agreement, including, without limitation, that your use is for
Info: the sole purpose of programming logic devices manufactured by
Info: Intel and sold by Intel or its authorized distributors. Please
Info: refer to the applicable agreement for further details.
Info: Processing started: Sun Jun 09 22:33:29 2019
Info: Command: quartus_eda --gen_testbench --tool=modelsim_oem --format=verilog --write_settings_files=on light -c light --vector_source=C:/Desktop/introtutorial2/Waveform.vwf --testbench_file=C:/Desktop/introtutorial2/simulation/qsim
Error: Quartus Prime EDA Netlist Writer was unsuccessful. 0 errors, 0 warnings
Error: Peak virtual memory: 4722 megabytes
Error: Processing ended: Sun Jun 09 22:33:32 2019
Error: Elapsed time: 00:00:03
Error: Total CPU time (on all processors): 00:00:02
Error.
Is the EDA Tool properly setup? Go to Tools -> Options -> EDA Tool Options and set the ModelSim-Altera directory.
example directory: C:\intelFPGA\18.1\modelsim_ase\win32aloem
Sharing your design might help with further understanding.
Thanks for the response . I have tried the suggested solution but it did not work.
Following is my design code
module light(x1,x2,f);
input x1,x2;
output f;
assign f=(x1 & ~x2)|(~x1 & x2);
endmodule
I am not able to run the functional simulation for the above code.
Kindly advise.
Your design works though. Is the EDA Tool Settings > Simulation > Tool Name, is set as ModelSim-Altera?
Or you can try the steps by steps guidance with below link and check whether the same issue occur again.
http://www.swarthmore.edu/NatSci/echeeve1/Ref/embedRes/QQS_V/QuickQuartusVerilog.html
