//////////////////// BCD TO DECIMAL //////////////////////////////
module DE10_LITE_Default( input [1:0]KEY,
input [9:0]SW,input CLK,
output [9:0]LED,
output [7:0]HEX_0,output [7:0]HEX_1, output [6:0]HEX_2, output [6:0]HEX_3); // HEXOUT_0
reg [3:0]module_select;
wire [7:0]add_out;
wire [9:0]math_carry;
Arithmetic math_block(SW[9:8],SW[7:0],math_carry[9],add_out[7:0]);
wire [9:0]logical_out;
Logical logic_block(SW[9:8],SW[7:0],logical_out[7:0]);
wire [3:0]compare_out;
Comparison compare_block(SW[9:8],SW[7:0],compare_out[3:0]);
wire [9:0]soultion_output;
solution(CLK, soultion_output[9:0]);
//display what the sub-module selection is on HEX_2
SevenSegment HEX2({1'b0,1'b0,SW[9],SW[8]},HEX_2[6:0]); // HEXOUT_2
//display what module number the user is in on HEX_3
SevenSegment HEX3(module_select[3:0],HEX_3[6:0]); // HEXOUT_3
//Use the first button to cycle one way through the different modules
always@(posedge KEY[0],posedge KEY[1])
begin
module_select = (module_select + 1) % 4;
end
//use multiplexors to switch between the different outputs on the first two HEX displays depending on the module selection
wire [3:0]HEX0_in;
MUX HEX0_MUX({4'b0000,compare_out[3:0],logical_out[3:0],add_out[3:0]},module_select[1:0],HEX0_in[3:0]);
defparam HEX0_MUX.n = 4;
SevenSegment HEX0(HEX0_in[3:0],HEX_0[6:0]); // HEXOUT_0
wire [3:0]HEX1_in;
MUX HEX1_MUX({4'b0000,4'b0000,logical_out[7:4],add_out[7:4]},module_select[1:0],HEX1_in[3:0]);
defparam HEX1_MUX.n = 4;
SevenSegment HEX1(HEX1_in[3:0],HEX_1[6:0]); // HEXOUT_1
//if the processor is in arithmetic mode, have the most significant decimal point match the multiplication carry,
//and least significant match the division carry
assign HEX_0[7] = ~(~module_select[0] & ~module_select[1] & SW[9] & SW[8] & math_carry[9]);
assign HEX_1[7] = ~(~module_select[0] & ~module_select[1] & SW[9] & ~SW[8] & math_carry[9]);
//use a 10 bit multiplexor to switch between the different outputs of the LEDs depending on the module selection
MUX LED_MUX({solution_output[9:0],10'b0000000000,logical_out[9:0],math_carry[9:0]},module_select[1:0],LED[9:0]);
defparam LED_MUX.n = 10;
endmodule
What is not working correctly? What exactly are you expecting? What have you tested? What is the code for the instantiated modules? Are you getting error messages?
More detail needed here.
#iwork4intel
Hi Kassy,
What are you expecting from thee design? Is there any error message you could provide?
