17260 Discussions
Hello, I have issues to copy/paste Block diagrams on Quartus Prime edition. Would you recommend something to solve this? Thank you in advance for your answer. Best regards, Fabrice
Fabe64
AnandRaj_S_Intel
Hi Fabrice,
Describe the steps also share information on Quartus edition & version Used.
ctrl+c & ctrl +v or
right click copy & right click Past in block diagram file works fine.
Anand
Fabe64
Hi Anand,
Thanks for your quick reply. I have the issue with Quartus Prime Version 17.0.0 for example. When I open a block diagram/schematic file and I right click copy a DFF symbol for example, when i want to paste it somewhere else into my block diagram/schematic file, right click Paste is in grey color.
Fabrice
AnandRaj_S_Intel
Hi Fabric,
I have checked it in Quartus std 17.0 it is working fine.
Are using Lite/Std/Pro?
Please do share image with diagram/schematic file right click Paste is in grey color.
Anand
Fabe64
Hi Anand,
Please, find below the images that I just took from Quartus. Feel free to ask me if you need more information.
Fabrice
AnandRaj_S_Intel
​Hi,
We have tried to replicate the scenario on Quartus 17.0 lite. However it worked fine on Quartus 17.0 & 17.1 LITE.
  1. try by reinstalling Quartus 17.0 lite
  2. Or use latest Quartus lite version.
Fabe64
Hi Anand,
I have also installed in same computer Quartus 18.1 Lite. And it seems that it does the same thing. I have a colleague which has Quartus 17.0 lite and this copy/paste functionality works.
Please, check the print screens which I just did.
Thank you in advance for your comments.
Fabrice
About Quartus Prime 18.1.jpgQuartus Prime Copy 18.1.jpgQuartus Prime Paste 18.1.jpg
AnandRaj_S_Intel
​Hi Fabrice,
Copy past operation Works fine in Quartus.
May be problem with Quartus Installation or environments (OS).
Try to install it in new pc.
Anand
Fabe64
Hi Anand,
Thanks for your recommendations.
Fabrice
AWrithingMassOfFlesh
I have this issue in v20.1.1
I cannot paste in block diagram view
@admin How do I fix this?
simong
I have the same issue.
Close all the other applications in backgroud,  try again.
Especially the applications in notification area.
I have found a solution to this issue.
On my system I was running an instance of VirtualBox with the shared clipboard plugin enabled.
For whatever reason when this plugin is enabled, Quartus does not allow pasting in block diagram view.
When I disable the shared clipboard plugin or close VirtualBox, I am able to copy and paste in Quartus.
To disable the shared clipboard in VitualBox go to
Machine --> Settings --> General --> Advanced --> Shared Clipboard --> Disabled
Perhaps this issue could also be caused by other programs which interface with the native operating system's clipboard?
