17268 Discussions
Help in Verilog Code: Edge Trigger
SS5
I am working with Altera Cyclone V FPGA Board.
Design Goal : I need to run counter using SOPC and NIOS
Design Process:
Using Verilog Code
  1. Generating Trigger for 500ns
  2. Generating Counter data
Help: I need to collect the counter data only at positive edge of Trigger signal (not at entire positive cycle of Trigger signal).
module Counter( input clk, // Clk: 50 Mhz input enable, input reset, output reg[31:0] Final_value, output reg trig ); reg[31:0] counter_out; reg [7:0] temp=0; wire detect; reg [31:0] counter_result; reg temp1; wire temp2; always@(posedge clk) begin if(reset) begin trig<=0; temp<=0; counter_out<=0; end else if (enable==1'b1) begin counter_out<=counter_out+1; temp<=temp+1; if(temp==25) begin temp<=0; trig<=~trig; temp1<=trig; // Generating Trigger for 500ns end end end   assign temp2=temp1&&clk; always@(posedge temp2) if(reset) counter_result<=0; else begin counter_result<=counter_result+1; // Increaming the Counter end assign detect = counter_result & ~temp1; // Positive Edge detect of Trigger always@(posedge detect) if(reset) Final_value<=0; else begin Final_value<=counter_result; end endmodule
I have tried but its not giving the correct results!
KhaiChein_Y_Intel
Could you elaborate? Does counter data refer to Final value? What is Trigger in this verilog code (trig or temp 1 or temp 2) ?
SS5
>>Does counter_result refer to Final value? Yes, But putting counter date at an edge value of Trigger into Final value reg.
trig
delay trig--- temp1
Please refer this link for detailed explanation
https://forums.intel.com/s/question/0D50P00003yyIqR/help-writing-c-code-for-niosiistratix-ii2s60?s1oid=00DU0000000YT3c&OpenCommentForEdit=1&s1nid=0DB0P000000U1Hq&emkind=chatterCommentNotification&s1uid=0050P000008Ifj2&emtm=1537424613585&fromEmail=1&s1ext=0
KhaiChein_Y_Intel
If you use posedge trig, the signal will be latched at the positive edge of the clock signal (trig) within the setup and hold window but not the entire positive cycle of the clock.
SS5
Sorry, Whether Verilog code is right ?? Please explain me briefly
KhaiChein_Y_Intel
Could you help me to understand why you are using detect as the clock signal for final_value?
SS5
Thanks for your response. As i have modified my design as per my head instruction. Now i am getting the output correctly.
