Help needed
Hi all,
I am trying to implement a 32 bit RISC processor on a Cyclone II FPGA. I'm using quartus 13.0 sp1 tool. I have coded a single stage of the pipeline so far. I have pasted the code below. The errors I have been getting are at lines 5&6
Error (12002): Port "IF_out" does not exist in macrofunction "d1"
Error (12002): Port "RR_in" does not exist in macrofunction "d1"
Error (12002): Port "IF_out" does not exist in macrofunction "i1"
Error (12002): Port "pc_fetch" does not exist in macrofunction "i1"
module risc32(pc_fetch,clk);
input clk;
input [31:0] pc_fetch;
reg[31:0] IF_out;
IF_decode i1 (.pc_fetch(in),.IF_out(out));
d_flip_flop d1 (.IF_out(d),.RR_in(q),.clk(clk));
endmodule
module d_flip_flop(d,q,clk);
input d,clk;
output reg q;
always@(posedge clk)
q<=d;
endmodule
module IF_decode(in,out);
input[31:0] in;
output reg[31:0] out;
reg [4:0] opcode;
wire [3:0]op_ext;
wire[22:0]arg;
wire [1:0]width;
wire [3:0] rd_reg0_num, rd_reg1l_num, rd_reg2_num;
wire [9:0]ofs;
wire [2:0]shift;
wire[7:0]k;
wire[4:0]k_shift;
always@(in, opcode)
begin
case(in[4:0])
5'b11101: out[4:0] = opcode;
5'b11110: out[4:0]= opcode;
5'b00000: out[4:0]=opcode;
5'b0xx01: out[4:0]=opcode;
5'b01110: out[4:0]=opcode;
default: out[31:0] = 32'bz;
endcase
end
endmodule
the . name refers to the port name on the module, not the local varaible. Plus RR_in isnt declared in any of your code.
