17254 Discussions
Help pls Nativelink TCL script failed with errorCode: 1
AzeemSyaz
sstrell
As it says, run Analysis & Elaboration or full synthesis from the Quartus Processing menu first.
Nurina
Does the above solution help?
Nurina
We did not receive any response to the previous question/reply/answer that I have provided, thus I will put this case to close pending. Please post a response in the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
Nurina
P/S: If you like my comment, feel free to give Kudos. If my comment solved your problem, feel free to accept my comment as solution!
