Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Valued Contributor III
Help with this code
Hi, I've written a verilog code for a function that finds root by bisection method but unfortunately it's not giving the right output,maybe because of choice of variable. Can anyone please help me out with this & let me know where I did wrong? I would really appreciate it!
The code & output is attached here.
Code:
module FT_1();
reg[32:0] upper;
reg[16:0] lower;
reg[16:0] root;
initial
begin
upper=3;
lower=0;
root= apu(upper,lower);
//$display("The root is: %f",root);
end
function[32:0] apu;
input[16:0] xu;
input[16:0] xl;
real xm;
integer i;
begin
for(i=0;i<=20;i=i+1)
begin
xm= (xu+xl)/2.0;
//apu=(xu+xl)/2.0;
if(((xm*xm)-2)<0)
begin
xl=xm;
end
else
begin
xu=xm;
end
apu=(xu+xl)/2.0;
$display("the root is= %f" ,xm);
end
end
endfunction
endmodule
Output:
# the root is= 1.500000# the root is= 1.000000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000# the root is= 1.500000
Highlighted
I'm not a Verilog expert, but when you do xl=xm; xu=xm;You convert xm to integers, as xl and xu are integers. I assume this isn't what you wanted.
Do you intend to put it in an FPGA later? Then you can't use reals anyway, and you would have to clock the process and add some pipelining to avoid an overly complex and slow design.
