17267 Discussions
Hi How can i launch Modelsim from quartus prime pro GUI? Help please? Kind Regards
OThys
AnandRaj_S_Intel
The Intel Quartus Prime Pro Edition does not support NativeLink simulation. If you use NativeLink for Intel Arria 10 devices in the Intel Quartus Prime Standard Edition, you must add the .qsys file generated for the IP or Platform Designer (Standard) system to your Intel Quartus Prime project. If you use NativeLink for any other supported device family, you must add the .qip and .sip files to your project.
We have to launch modelsim manually.
Anand
