16593 Discussions
Hi, I am currently doing a project about Built-In Self Test and I used my BIST to test on a 8 bit full adder circuit, but the simulation turned out that my FA inputs are showing 1111 1111 instead of transferring test patterns from LFSR.
BGuan1
I suspect the problem is with the LFSR configurations, but I am not sure where, here I attached with the LFSR testbench, codes and the simulation result. SOS!!!!
ShafiqY_Intel
Hi BGuan1,
I may need your VHDL code file and TB file to duplicate it.
And also, can you explain step-by-step how you simulate? (I need to understanding on how you simulate the project)
Looking forward for your reply.
Thanks 😉
