16025 Discussions
Hi I have this piece of code: in a package i have the record declaration (unconstrained): modelsim is able to compile it, but quartus not (VHDL 2008). I tried 15.1 and 18 version . how can i overcome this without constraint the record in the package?
GHe
entity U1 is generic ( POS_CONFIG_1 : positive := 8; POS_CONFIG_2 : positive := 75; POS_CONFIG_3 : positive := 10; POS_CONFIG_4 : positive := 48; POS_CONFIG_5 : positive := 4 ) ; port (   IN_REC_DVP_BUS : in DvpBus(data(POS_CONFIG_1-1 downto 0), xpos(bwidth(POS_CONFIG_2+POS_CONFIG_3)-1 downto 0), ypos(bwidth(POS_CONFIG_4+POS_CONFIG_5)-1 downto 0)); OUT_REC_DVP_BUS : out DvpBus(data(POS_CONFIG_1-1 downto 0), xpos(bwidth(POS_CONFIG_2+POS_CONFIG_3)-1 downto 0), ypos(bwidth(POS_CONFIG_4+POS_CONFIG_5)-1 downto 0));   CLK_0 : in std_logic ; RST_0 : in std_logic ) ; end entity U1;         type DvpBus is record SAMP : std_logic; VALID : std_logic; DATA : std_logic_vector; XPOS : unsigned; YPOS : unsigned;   end record DvpBus;             Error (10410): VHDL Type Conversion error at u1.vhd(71): Type Conversion near text or symbol "DvpBus" must have one argument
Tricky
New Contributor II
Quartus Prime Standard only ever had limited 2008 support, and unconstrained record types was never a supported feature.
Prime Pro has full 2008 support.
Only answer is to use prime pro, or constrain the record type definition.
