16339 Discussions
Hi, I would like to know if you could provide me some sample code for connecting the interrupt from a customized module to PCIE hard IP which is enabled as Avalon-MM with DMA in platfrom designer for Arria10. Regards, Sabitha
sabitha
I would like to generate an interrupt to the user code on host(CPU) over PCIE once some processing is done from FPGA(Its not End of DMA Transfer, needed customized interrupt in addition to the end of DMA transfer).
