LIBRARY ieee;
USE ieee.std_logic_1164.all;
LIBRARY work;
ENTITY pract3 IS
PORT
clk : IN STD_LOGIC;
I_0 : IN STD_LOGIC_VECTOR (0 TO 3);
I_1 : IN STD_LOGIC_VECTOR (0 TO 3);
I_2 : IN STD_LOGIC_VECTOR (0 TO 3);
I_3 : IN STD_LOGIC_VECTOR (0 TO 3);
Oper : IN STD_LOGIC_VECTOR (2 DOWNTO 0);
act_dis1: OUT STD_LOGIC;
act_dis2: OUT STD_LOGIC;
act_dis4: OUT STD_LOGIC;
act_dis3: OUT STD_LOGIC;
C_out : OUT STD_LOGIC;
--D : OUT STD_LOGIC_VECTOR (0 TO 1);
display : OUT STD_LOGIC_VECTOR (6 DOWNTO 0);
oper_led: OUT STD_LOGIC_VECTOR (2 DOWNTO 0)
END pract3;
ARCHITECTURE bdf_type OF pract3 IS
COMPONENT Practica2
PORT
clk : IN STD_LOGIC;
I0 : IN STD_LOGIC_VECTOR (0 TO 3);
I1 : IN STD_LOGIC_VECTOR (0 TO 3);
I2 : IN STD_LOGIC_VECTOR (0 TO 3);
I3 : IN STD_LOGIC_VECTOR (0 TO 3);
dec : OUT STD_LOGIC_VECTOR (0 TO 3);
sal : OUT STD_LOGIC_VECTOR (6 DOWNTO 0));
END COMPONENT;
COMPONENT arithmetic_circuit
PORT
C_in : IN STD_LOGIC;
A : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
B : IN STD_LOGIC_VECTOR (15 DOWNTO 0);
S : IN STD_LOGIC_VECTOR (1 DOWNTO 0);
G : OUT STD_LOGIC_VECTOR (15 DOWNTO 0)
END COMPONENT;
COMPONENT binary_to_bcd
GENERIC
bits : INTEGER := 16; --bits of the binary input
digits : INTEGER := 4 --number of BCD digits to convert to
PORT
clk : IN STD_LOGIC; --sys clk
reset_n : IN STD_LOGIC;
ena : IN STD_LOGIC; --enable
binary : IN STD_LOGIC_VECTOR(bits -1 DOWNTO 0); --num to convert
busy : OUT STD_LOGIC; --indicates conversion in progress
bcd : OUT STD_LOGIC_VECTOR(digits *4-1 DOWNTO 0) --BCD number
END COMPONENT;
SIGNAL A_in : STD_LOGIC_VECTOR (15 DOWNTO 0);
SIGNAL B_in : STD_LOGIC_VECTOR (15 DOWNTO 0);
SIGNAL BCD : STD_LOGIC_VECTOR (0 TO 15);
SIGNAL G : STD_LOGIC_VECTOR (15 DOWNTO 0);
BEGIN
oper_led <= Oper;
b2v_inst_Practica2 : Practica2
PORT MAP
clk => clk ,
dip_1 => BCD(12 TO 15),
dip_2 => BCD(8 TO 11),
dip_3 => BCD(4 TO 7),
dip_4 => BCD(0 TO 3),
dec_D0 => act_dis1 ,
dec_D1 => act_dis2 ,
dec_D2 => act_dis3 ,
dec_D3 => act_dis4 ,
--D => D,
sal => display
PORT MAP
C_in => Oper(2),
A => A_in ,
B => B_in ,
S => Oper(1 DOWNTO 0),
C_out => C_out,
G => G
stbin : binary_to_bcd
PORT MAP
CLK => clk ,
reset_n => ’1’,
ena => ’1’,
binary => G,
bcd => BCD
A_in(7 DOWNTO 4) <= I_0;
A_in(3 DOWNTO 0) <= I_1;
B_in(7 DOWNTO 4) <= I_2;
B_in(3 DOWNTO 0) <= I_3;
A_in (8) <= ’0’;
A_in (9) <= ’0’;
A_in (10) <= ’0’;
A_in (11) <= ’0’;
A_in (12) <= ’0’;
A_in (13) <= ’0’;
A_in (14) <= ’0’;
A_in (15) <= ’0’;
B_in (8) <= ’0’;
B_in (9) <= ’0’;
B_in (10) <= ’0’;
B_in (11) <= ’0’;
B_in (12) <= ’0’;
B_in (13) <= ’0’;
B_in (14) <= ’0’;
END bdf_type;
The error we're getting is:
Error (10500): VHDL syntax error at pract3.vhd(88) near text "PORT"; expecting "end", or "(", or an identifier ("port" is a reserved keyword), or a concurrent statement
You have a port map with no label or entity name
Thank you so much for your help, but we're not quite sure what you mean. Also, why are we getting the error on the second PORT MAP but not on the first? Thanks once again :)
Line 88, you have a port map without specifying what component you're actually port mapping
