17240 Discussions
High Speed Reed solomon intel FPGA IP
Rk_Athram
I am using High speed reed solomon Intel FPGA IP and simulating using model sim for the polynomial 1033 and parallelism of 2 with each symbol being 10bits. I would like to know how do i verify the parity values/check symbols generated from the IP
thank you
RK
ZiYing_Intel
Hi RK,
Thanks for submitting the issue. Please do allow me have some time to look into your issue and I will get back to you with findings.
Zi Ying
ZiYing_Intel
Hi RK,
You may check whether the value is a legal value through the table of parameters, Table 11, pg 23,
ZiYing_Intel
Hi RK,
Since I have addressed your question and haven't hear any feedback from you, I am now close the case. If you have any question after the case closed, please do feel free to submit another issue.
Zi Ying
