How can I Fix?
Hiro
 I'm beginner.
When I use Convert Programming File , I got this message.
"No input file specified"
How can I Fix?
sstrell
You have to specify the input .sof file.  Double-click where it says SOF Data or click Add File to pick the file.
NurAiman_M_Intel
Thank you for contacting Intel community.
You may refer to sstrell answer for this case. Or you may look into the link below for example of convert programming file for Max10:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/max-10/ug_m10_config.pdf
Aiman
