17267 Discussions
How can I generate a .bench file
MHamz1
I am using a tool for certain analyses on the netlist, the tools accepts the .bench file .
Is there a way to generate .bench file from quartus . Any help ?
JoanneSinY_L_Intel
Do you mean test bench file? Here is the simple example
You can get Quartus to produce a shell testbench file by selecting Processing | Start | Start Test Bench Template Writer
http://denethor.wlu.ca/pc120/quartus_testbench.shtml
Joanne
