17192 Discussions
How can I use the LUT chain interconnect?
SYosh17
I want to create 6-input NAND gate using the LUT chain interconnect.
I'm using Cyclone IV.
JohnT_Intel
If you look into https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/cyclone-iv/cyiv-51002.pdf, the carry chain can only be used in Arithmetic mode. So it is not possible to implemented using NAND gate.
JohnT_Intel
When you implement your design (6-Input NAND gate) it will directly optimize the design and use LUT chain interconnect when necessary. There is no way to manually implement it.
SYosh17
Thank you for answering.
I implement very simple example of 6-input NAND. The place and route result of this design using 2 LE, which placed different LAB. I think it does not use LUT chain interconnect. I attached the project files.
JohnT_Intel
SYosh17
