16737 Discussions
How can i use m25p32 flash, quartus only have epsc16 or epcs64, there is no Similar device epcs32!Is there a configuration file?
BLADI
How can i use m25p32 flash in quartus ?there is only have epsc16 or epcs64, there is no Similar device epcs32!Is there a configuration file? i program ep4ce40 by jic file
epcs16 epcs64 and m25p32 ,it is same controlling method, and same sector size, only difference number of sectors!
BLADI
Vicky1
Please conform the below solution from below links,
  1. https://forums.intel.com/s/question/0D50P00003yySq0SAE/programming-an-m25p32-serial-flash-using-quartus-programmer-131?t=1542935553572
  2. https://forums.intel.com/s/question/0D50P00003yyM8QSAU/problem-with-programming-the-m25p32-using-a-jam-file
I hope it may help.
Best Regards
Vikas Jathar
(This message was posted on behalf of Intel Corporation)
