After completing the Programmer for the code in the board that I am using, how can I display the content of the code on an external screen? I used a vga cable between the port and a side screen? Are there other things I should do..... I programmed the tic tac toi game and I programmed its code on the board (DE10-LITE) after that I used a vga cable to connect the screen to the board in order to display the game on the screen, but This did not happen. What is the problem and how can I display the game on the screen? Is there a specific step or thing that I must do
You do know that the VGA connector on that board is just a simple connector attached to the FPGA pins via D/A resistor ladders.
There is no inherent VGA display capability UNLESS you implement a VGA video generator function in your FPGA logic.
For reference, the TerASIC system CD "DE10-Lite_v.2.1.0_SystemCD" for that board has a VGA demonstration application in
the Demonstrations / VGA_Pattern folder. You should look at that.
The TeraASIC support CD ISO image is available for download here:
in case you don't already have it.
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
regards,
Farabi
