How do i copy macro
Fenchia_studentM0907
Hi I am a student 。
I'm learning Quartus but I have some problems。
I created an A module and used two A modules in the TOP module。
Sorry, so I want to know how to make the same placement and routing of these two modules。
thanks。
Nurina
I'm assuming all your modules are in block design files (.bdf) format. If you just add the module A symbol in your top level file then the place and route should not change.
Nurina
Thanks for your reply。
I design one spi module by using verilog , in my project  I need to use two SPI Modules.
I hope the place & route of these two are the same because I hope they have the same timing, but according to my understanding, the bdf file is  designed with logic gates, so I think this method maybe not fit my usage situation.
Nurina
I must apologise, my first reply has a mistake. It's almost impossible to have the same exact place & route for the same two modules in a top level module.
By same timing I'm assuming you're talking about timing closure. You can refer here on what you can do to achieve that:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an584.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an903.pdf
https://www.youtube.com/watch?v=HMAqjjCuDEI
Nurina
Thank you very much for taking the time to answer my question.
Sorry, I saw qxp file while reading the information a few days ago. I would like to ask if qxp file can achieve my goal.
Nurina
No, it wouldn't. I suggest using Timing Analyzer, here you will be using .sdc file to set timing constraints. Since your concern is related to place and route, use post-fit netlist when you create timing netlist.
This video lecture explains how you can do that: https://www.youtube.com/watch?v=79mtPfAm1TA&list=RDCMUC0wEPiFb0J6AZZ3oPXRoRpw&index=3
The following videos are part of the same video lecture series which can be useful for you:
https://www.youtube.com/watch?v=6LYvXTaMto0&list=RDCMUC0wEPiFb0J6AZZ3oPXRoRpw&index=11
https://www.youtube.com/watch?v=ggWxledaBFg&list=RDCMUC0wEPiFb0J6AZZ3oPXRoRpw&index=5
I included the first video lecture on my previous reply.
You might find this timing analyzer tutorial to be useful: https://www.intel.com/content/www/us/en/programmable/documentation/caf1499898833805.html
Nurina
Thank you very much for taking the time to answer me.
I will study the information you gave me, thank you.
Nurina
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
