Hello, I am working on a design using Arria 10 GX. I included a DDR4 EMIF IP that wants a reference clock for its PLL(s). This reference clock is placed on a clock input pin.
I also need to generate some other frequencies for totally separate clock domain. But rather than cascade the EMIF PLL, I want to just feed my input clock to both the EMIF PLL and my other PLL.
If I do this without any constraints added, the fitter complains that it cannot place one of the PLLs.
If I force my input clock signal to be a global clock, then the fitter does not complain, but I have some very strange issues later on with clock constraints that I place on the input pin not propagating to the EMIF PLL.
I will mention that this design is one that used to be in a Stratix II GX part, and the tools at the time hooked up the PLLs without any issue.
Anyone know why the tools can't hook these clocks together?
Sree,
Thank you for answering. One of the first things I tried is to instantiate an ALTCLKCTRL. This had no effect, it was still unable to place my PLL. IIRC, without constraining the input to be a global or a regional clock, the tool said it could not place the PLL in 8 places that it tried. I can get the exact error message if it is helpful.
I have placed the EMIF in banks in 3A, 3B and 3C. The input clock pin is in bank 3B, pins Y6/Y7.
The EMIF pll is placec at IOPLL_3B and I believe it duplicates this in 3A and 3C. My pll (when I constrain the input to be a global clock) gets placed in IOPLL_2L.
Even though my input signal is placed where the EMIF wants it (it chose the pin locations), I get warnings from the Timing Analyzer that it cannot determine the master clock for the EMIF pll. It says candidates are inclk_133 (my signal name for the input clock) and emif_0_ref_clk (the input reference to the EMIF pll) which is fed from inclk_133.
As a quick experiment, I removed the connection to my pll and instead fed its reference from an output from the EMIF pll. So, now inclk_133 feeds the EMIF pll, the EMIF pll outputs a clock of same frequency and that feeds 2nd pll (whose outputs are unrelated and in another clock domain) as well as the rest of the FPGA fabric. I get the same exact warning from the Timing Analyzer that it cannot determine the master clock for the EMIF pll with the same 2 candidates. The result of this tells me that my timing analyzer problems are not a result of connecting the 2 plls to the same input clock but rather a problem with the EMIF IP does not like my input clock. Maybe it wants it to have a particular name...
So how to I tell the Timing Analyzer to use one of those clocks for the master? The sdc file for the EMIF is auto-generated and does not look like I should mess with it even if I could decipher it:-).
Bill
Hello Bill,
Apologize for the delay in response ; Actually i missed your updated post ,
As you mentioned , you can create the one more sdc constraint file and add to the project and specific the clock input in the sdc. It just need to match the signal name and sdc port name.
Thank you ,
Sree
