17255 Discussions
How to assign to HPS_UART_RX pins?
TSCHE16
Hi there,
I'm using the TSoM Evaluation Kit with a Cyclon V.
I'm trying to write a simple echo program using the UART protocoll. In the manual I found the HPS_UART_RX and HPS_UART_TX with Pin No. PIN_A22 and PIN_B21.
I also checked out the demonstration comming with the CD in which these pins (and others for USB data exchange) are used.
My Question is: How do I assign these pins in the pin planer in Quartus 2 software, because I can't select them in my project?!
EBERLAZARE_I_Intel
You can open in the Assignments Tab in Quartus, then select Pin Planner, then you may assign pins in the Location Tab in the table at the bottom.
May I know which Quartus version you are working on?
Regards.
TSCHE16
hi,
thx for your response. Like I said, I can't select them. Apparently we are talking about HPS GIOs (pic is from the handbook), which I can't assign to my inputs and outputs in my VHDL project. At least not like I used to do it with the pin planner.
In a demo on the CD I found a Verilog project, which managed to assign these HPS GIOs (HDMI, DDR, USB, etc). In the manuals I found this:
The board provides 25 HPS GPIOs (3.3V), which are connected directly to the Cyclone V SoC HPS. [...] Each HPS I/O corresponds to different HPS peripheral controllers, users can set these peripheral controllers through the Qsys built in
Quartus software.
So I tried Qsys, but just had no luck with it. Also the demo project didn't add any components with Qsys (as far as I can tell).
I'm working with Quartus 17.1
EBERLAZARE_I_Intel
It is really unclear on the situation, can you screenshot where it cannot be selected?
