16911 Discussions
How to avoid Quartus to merge MegaWizard function after Fitter?
NuvKFC
I have three instances, A, B, and C. All of them use the same IP module which contain PLL MegaWizard function file.
It means that A=B=C.
After Fitter, Quartus only implements a PLL for those three instances using.
Then SDC file can't find the PLL port to create the clock.
The question is that how to keep the PLL MegaWizard function after Fitter?
In other words, how to avoid Quartus to merge PLLs?
Quartus can implements three PLL MegaWizard function for those three instances.
Thank you very much.
NuvKFC
Ash_R_Intel
This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
NuvKFC
Hi Ash_R_Intel
    OK. Thank you very much.
