16701 Discussions
How to communicate between custom software and FPGA using JTAG?
POvch
I have to implement a pc (Linux and Windows) application which has a GUI and can read from and write to a FPGA using JTAG. Also some other functionalities for analysis. I've implemented an application using TCL and system console but the result isn't satisfying.
Now I'm writing a java application but need some libs or services to implement "master_read_32" and "master_write_32". As in altera_jtag_to_avalon_mm_tutorial mentioned, using jtagservice/jtagd seems to be the right direction but makes a lot of trouble for me. First, I can't find any documentation how to use jtagservice or what is jtagservice exactly for. Second, I've to enable port TCP 1309 (https://www.doulos.com/knowhow/fpga/remote_programming/) which I am not allowed to.
Any suggestions how to make read and write happen?
Thank You
Pavel
JohnT_Intel
This is not supported. The only method to use System Console is by utilizing Intel FPGA blaster.​
POvch
Hi John,
I guess that my description is a bit misleading. PC isn't connected to the JTAG directly, we are using USB Blaster. The solution with the system console works already, but we don't want to use it. Therefore I'm looking for another way to control the USB Blaster via my java application.
Hopefully, my language is understandable.
JohnT_Intel
Unfortunately, there is no way to interface with it other than System Console.
POvch
ok, thank you very much John.
Then I'll use system console as a subprocess. As like https://stackoverflow.com/a/34800683 , but with java.
