17094 Discussions
How to generate JAM file from pof
mxy_bw
Hi, I am using STAPL to program Cyclone IV E. I already have a .sof file and converted it to .pof file with "configuration device"  EPCQ16 and "AS" mode. Then in "programme" window I added this .pof file with "AS" mode, but the "Create JAM,JBC, SVF or ISC file" menu is not clickable. So how do I get a jam file from pof? Any other condition or steps? Hope for reply, thanks!
Fakhrul
Hi mxy_bw,
Creating a JAM file from a POF file is a straightforward process. Here's how you can do it:
  1. Open the Programmer tool in the Quartus design system.
  2. Use the 'Add file' option to load the POF file you want to convert.
  3. Go to the 'File' menu and select 'Create JAM, JBC, SVF or ISC File...'.
  4. In the 'Create...' dialog, choose the desired file format and file name, then click 'OK'.
  5. There are no additional options for the JAM file format because it encapsulates all necessary actions.
  6. You can generate a JAM file without connecting to a programmer hardware.
Fakhrul
Fakhrul
As we do not receive any response from you to the previous notification that we provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
