17117 Discussions
How to get the Quartus license
dsun01
New Contributor III
Dear Support,
I just bought a brand new DK-Dev-10AX115S-A, It should has one year license associated to the board. How to get the valid license in this case?
Thank you,
David
AR_A_Intel
Hi Sir
Welcome to INTEL forum. Regarding license activation, the development kit comes with a serial number that is stated either on the box or a customer letter. You can check with the dealer where you purchased the development kit.
This serial number serves as a license activation code to activate your Quartus software license via the Self-Service Licensing Center. Check if the software DKE license is visible in the Products and Users View in Self-Service Licensing Center. If the license is visible, no activation is needed. You may proceed to create the new license file. If the license is not visible, the serial number will be the activation code for you to activate the license.
refer to our user guide.
https://www.altera.com/content/dam/altera-www/global/en_US/pdfs/education/demonstrations/online/licensing/how-to-activate-license.pdf
AR_A_Intel
Hi Sir
dsun01
New Contributor III
thank you very much for prompt reply, even I don't think it is very easy to use, but after sometime I figured out and got the license file. thank you very much.
David
AR_A_Intel
Sounds good, hope everything is working well at your side. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
