17255 Discussions
How to implement a module for accessing single block of on-chip memory in systemverilog?
KTsan
Let say I want to model a 8 x 1024 bits Ram.
I can generate a Single Port Ram Module from IP Catalog.
I can access the on-chip memory via a single instance of this "Single Port Ram" module.
However, I have multiple modules which may access this single block of on-chip memory.
By creating multiple instances of "Single Port Ram", it actually instantiate duplicated blocks of on-chip memory per "Single Port Ram" module.
So, I am look for a real example in systemverilog on how to model a module for accessing a single block of on-chip memory by multiple instances of modules.
Please kindly help.
Tricky
New Contributor II
You need an arbiter. With multiple masters for a single ram, you need some logic to decide who gets to access the ram in any given cycle.
for example:
always @(posedge clk) begin if (we(0) ) begin mem_we <= we[0]; mem_din <= din[0]; end else begin mem_we <= we[1]; mem_din <= din[1]; end end
Here, channel 0 has priority over channel 1. With several masters, arbitration schemes can get more complicated - modes like round-robin or lowest port priority are pretty common.
KTsan
Sorry about that if I didn't clearly state the issue here. The real problem is : I cannot instantiate two modules for accessing single block of memory.
Let say I have a single port ram module:
module single_port_ram ( input [15:0] data, input [7:0] addr, input we, clk, output [15:0] q );   // Declare the RAM variable reg [15:0] ram[63:0]; // Variable to hold the registered read address reg [7:0] addr_reg; always @ (posedge clk) begin // Write if (we) ram[addr] <= data; addr_reg <= addr; end // Continuous assignment implies read returns NEW data. // This is the natural behavior of the TriMatrix memory // blocks in Single Port mode. assign q = ram[addr_reg]; endmodule
I have a top module which connect to two single_port_ram modules for reading 16 bits data at addr1 and addr2 respectively.
logic[15:0] data1, data2; logic[7:0] addr1, addr2; logic[15:0] out1, out2;   single_port_ram ram1 ( data(data1), addr(addr1), we(0), clk(clk), q(out1) );   single_port_ram ram2 ( data(data2), addr(addr2), we(0), clk(clk), q(out2) );
You can see ram1 and ram2 are actually TWO separated ram blocks (which is not my intent) as I declare the single_port_ram module twice.
What I want to do is : to have a single module (probably with port interface?) for accessing SINGLE block of memory so that I can create multiple instances of this module in different top modules for accessing same block of memory.
A stackoverflow user had the same issue and someone suggest to create port interface.
https://electronics.stackexchange.com/questions/79530/accessing-ram-instance-from-multiple-modules-in-verilog
Since I am new to systemverilog, I am looking for a real example which can illustrate how it works.
Ken
