Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
How to know what Quartus version was used for compilation from QAR (Project Archive) file?
Jump to solution
Hi All,
From QAR (Quartus Archive Project) file, is it possible to understand what version of Quartus was used for creation the archive/compilation of the project?
Thank you!
Accepted Solutions
Highlighted
Re:How to know what Quartus version was used for c...
Jump to solution
What you can do is install the latest version of Quartus Prime, open the qar.
After that, go to the project directory and look for *.qsf files. Open *.qsf files with notepad, and you able to see which Quartus was original built.
Highlighted
Jump to solution
Highlighted
Valued Contributor III
Re: How to know what Quartus version was used for compilation from QAR (Project Archive) file?
Jump to solution
I don't have one handy to check right now, but I think the .qarlog text file that is generated when you create a .qar would have this info as well.
#iwork4intel
Highlighted
Jump to solution
Since this thread had been mark as accepted solution, we shall close this thread. After 15 days, this thread will be transitioned to community support. The community users will be able to help you with your follow-up questions.
