17049 Discussions
How to make a averager in VHDL
I have just readed a piece of VHDL code. It is used to average the signal value from AD(14 bit).
The code i write below here:
process(CLK80) begin
if(CLK80'event and CLK80='1') then
if(samplingTriggerReg='1') then -- synchronization with the sampling trigger
avCStateReg <= "00000";
else
case avCStateReg is
when "00000"=> if(sigCLatchReg='1') then avCStateReg<="00001"; end if;
when "00001"=> if(sigCLatchReg='1') then avCStateReg<="00011"; end if;
when "00011"=> if(sigCLatchReg='1') then avCStateReg<="00111"; end if;
when "00111"=> if(sigCLatchReg='1') then avCStateReg<="01111"; end if;
when "01111"=> if(sigCLatchReg='1') then avCStateReg<="11111"; end if;
when "11111"=> if(sigCLatchReg='1') then avCStateReg<="11110"; end if;
when "11110"=> if(sigCLatchReg='1') then avCStateReg<="11100"; end if;
when "11100"=> if(sigCLatchReg='1') then avCStateReg<="11000"; end if;
when "11000"=> if(sigCLatchReg='1') then avCStateReg<="10000"; end if;
when "10000"=> if(sigCLatchReg='1') then avCStateReg<="00000"; end if;
when others => avCStateReg<="00000";
end case;
end if;
end if;
end process;
dfTrigCReg <= '1' when avCStateReg="10000" else '0';
avSStateReg <= "00000";
else
case avSStateReg is --gray counter?
when "00000"=> if(sigSLatchReg='1') then avSStateReg<="00001"; end if;
when "00001"=> if(sigSLatchReg='1') then avSStateReg<="00011"; end if;
when "00011"=> if(sigSLatchReg='1') then avSStateReg<="00111"; end if;
when "00111"=> if(sigSLatchReg='1') then avSStateReg<="01111"; end if;
when "01111"=> if(sigSLatchReg='1') then avSStateReg<="11111"; end if;
when "11111"=> if(sigSLatchReg='1') then avSStateReg<="11110"; end if;
when "11110"=> if(sigSLatchReg='1') then avSStateReg<="11100"; end if;
when "11100"=> if(sigSLatchReg='1') then avSStateReg<="11000"; end if;
when "11000"=> if(sigSLatchReg='1') then avSStateReg<="10000"; end if;
when "10000"=> if(sigSLatchReg='1') then avSStateReg<="00000"; end if;
when others => avSStateReg<="00000";
end case;
end if;
end if;
end process;
dfTrigSReg <= '1' when avSStateReg="10000" else '0';
process(CLK80)
begin
if (CLK80'event and CLK80='1') then
if (sigCLatchReg='1') then
avSigCReg(0)
<= sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg;
for I in 1 to 9 loop
avSigCReg(I) <= avSigCReg(I-1)
+ (sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg);
end loop;
end if;
end if;
end process;
process(CLK80)
begin
if (sigSLatchReg='1') then
avSigSReg(0)
<= sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg;
avSigSReg(I) <= avSigSReg(I-1)
+ (sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg(13) & sigSReg);
end loop;
end if;
end if;
end process;
i dont konw why the designer do this&#65306; avSigCReg(0) <= sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg;
avSigCReg is is array (0 to 9) of signed(17 downto 0)&#65292;
I think this code is calculate the average value of 10 signal .
But I dont understand it ? Thanks for giving your idea.
Use simulator, waveform says more than unknown code.
Yup, write a testbench and get simulating.
But you dont really specify exactly what you want? what exactly are you averaging?
Notes on your code:
- You dont show the whole code, so we cannot see signal declarations
- WHy have you got a for loop summing together things?
- This code looks messy
A moving window average is easily acheived with a shift register and an adder tree, with a divider on the end. If the window is 2^n wide, all you need to divide is drop the n LSBs (with a possible rounding stage)
--- Quote Start ---
--- Quote End ---
The common arithmetic average of N samples is calculated by summing the samples and then dividing by N.
Since division by a number which is not power of 2 is resource consuming, you can avoid it by discarding the N factor which is actually not relevant since it's simply a constant multiplier.
The multiple & sigCReg(13) simply serves for the purpose of sign extending the 14 bit ADC sample to the 18 bit wide sum.
Yes&#65292;Thanks for your reply .I have made simulation for this code.It looks like just summing the ten numbers last received from the AD.
--- Quote Start ---
Notes on your code:
--- Quote End ---
I didn't show the whole code because it's very long.This code is writen by others and I just want to know what exactly it work and use it in my work. I have writen a copy for simulation. I will put it below.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity Averager is
port(CLK80: in std_logic;
sigCReg: in signed(13 downto 0);
SigSReg: in signed(13 downto 0);
samplingTriggerReg: in std_logic;
sigCLatchReg: in std_logic;
sigSLatchReg: in std_logic;
dfTrigSReg :out std_logic ;
dftrigCReg: out std_logic;
WS0: out signed(17 downto 0);
WS1: out signed(17 downto 0);
WS2: out signed(17 downto 0);
WS3: out signed(17 downto 0);
WS4: out signed(17 downto 0);
WS5: out signed(17 downto 0);
WS6: out signed(17 downto 0);
WS7: out signed(17 downto 0);
WS8: out signed(17 downto 0);
WS9: out signed(17 downto 0)
end Averager;
architecture Behavioral of Averager is
signal avCStateReg, avSStateReg: std_logic_vector(4 downto 0):="00000";
type avSig is array (0 to 9) of signed(17 downto 0);
signal avSigSReg,avSigCReg: avSig;
begin
else
case avCStateReg is
end case;
end if;
end if;
end process;
else
end case;
end if;
end if;
end process;
process(CLK80)
begin
avSigCReg(0)<= sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg;
avSigCReg(I) <= avSigCReg(I-1)+ (sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg(13) & sigCReg);
end loop;
end if;
end if;
end process;
process(CLK80)
begin
avSigSReg(0)
end loop;
end if;
end if;
Ws0<=avSigcReg(0);WS1<=avSigcReg(1);WS2<=avSigcReg(2);WS3<=avSigcReg(3);WS4<=avSigcReg(4);
Ws5<=avSigcReg(5);WS6<=avSigcReg(6);WS7<=avSigcReg(7);WS8<=avSigcReg(8);WS9<=avSigcReg(9);
end process;
end Behavioral;
I have simulate it, it looks like adding the ten value last received from the AD. The divider is not occured in this part of code(or just discarding). I wanted to know more about a shift register and an adder tree you have mentioned.
Thanks for your reply. I'm a new learner so that I don't understand why this code is messy.
--- Quote Start ---
--- Quote End ---
Than you for your reply. But whether you mean I can discard the 10(the N in this code),and calculate the turth value when those datas uploaded to the computer.
For averaging 2^n samples all you need is discard n LSBs from result of accumulator (as explained in some of above posts). for non power of 2 samples there are some tricks to avoid division e.g. if number of samples is 1000 then average = sum/1000 = sum/1024 * 1.024
~= sum/1024 *(1+1/64+1/128)
hence average = sum(discard 10 LSBs) + sum(discard 16 LSBs) + sum(discard 17 LSBs)
--- Quote Start ---
--- Quote End ---
Thanks ,Kaz! It's a wonderful ideal !!!
--- Quote Start ---
--- Quote End ---
Ok Kaz, but this way you need more system resources, I mean logic gates in fpga or computation time in a programming language.
In other words you are still implementing some sort of division algorithm.
I would keep on my idea, which is also the one exploited by the sample code at start of this thread: if you don't mind the x1000 (or whatever) factor you can quietly avoid the division. If you later need to compare this 'average x 1000' with something else, it will be easier to multiply this one x1000 than dividing the average result.
--- Quote Start ---
--- Quote End ---
Yes I needed two adders (not that bad as a divider).
I agree you don't need to divide if you want the sum rather than the average but in many cases we do need the average itself over a given time window.
hi kaz&#65281;
Maybe I can ask you another VHDL code after this one. The data which is summed will be taken into a digital filter. The code is shown below:------------------- FIR FILTER ------------------
process(CLK80)
begin
if (DFTrigCReg='1') then
for I in 0 to firLength-1 loop
CQRealReg(I) <= avSigCReg(9)(17 downto 4) * DFcoeff(I);
end loop;
CSRealReg(0) <= CQRealReg(0)(23) & CQRealReg(0)(21 downto 0);
for I in 1 to firLength-1 loop
CSRealReg(I) <= CSRealReg(I-1) + (CQRealReg(I)(23) & CQRealReg(I)(21 downto 0));
end loop;
end if; --
end if; -- CLK
end process;
I think the DFcoeff is filter coefficient. But why the designer do the process like this" CSRealReg(0) <= CQRealReg(0)(23) & CQRealReg(0)(21 downto 0);"
That will be sign extension, ensuring that the slices arrays stay +ve or -ve correctly.
It reads better if you use the resize() function.
Looking at that code, it wont build the adder tree as I expect it, it just creates FirLength-1 output values (you usually end up with a single output).
--- Quote Start ---
--- Quote End ---
Yes, but I dont know the resize() function. And maybe the CSRealReg(FirLength-1) is the output which I want . If you're interesting the complete vhdl code you can see it in the attchment, Tricky. Thanks for your help.
