I have followed this topic Simulating Designs with Lower-Level Qsys Systems as example design.
But i want to read the counter incremented data in NIOS console. Please suggest me , how .
Shall i add PIO- 8-bit output in SOPC builder and whether it can be possible to read ? ?
Yes - you can add another PIO - configured as an input - and connect your 'count'' output signal to it. You can then use an 'IORD' instruction to read the value of the port.
Cheers,
Alex
Thanks for your response.
Please check my NIOS_code. Without FOR LOOP, how should i run the counter module.
#include "sys/alt_stdio.h"
#include "alt_types.h"
#include<io.h>
#include<system.h>
#include<stdio.h>
int main()
int result,i;
IOWR(ENABLE_BASE, 0, 0x0); // Enable the counter
alt_printf("Hello from Nios II!\n"); // Send Hello World to the JTAG UART
usleep(100);
for (i=0;i<10000;i++)
result=IORD(COUNTER_OUT_BASE, 0);
printf("%d\n",(result+i));
// IOWR(ENABLE_BASE, 0, 0x1);
return 0;
I am not sure whether my design flow is right ?
Please suggest me
module counter ///SUB
input clk, enable, rst_n,
output reg[7:0] count
always @ (posedge clk or negedge rst_n)
begin
if (~rst_n)
count <= 0;
else if (enable == 1'b1)
count <= count + 1;
end
endmodule
module Counter_Top_Level_design ///TOP
input clk,
input rst_n,
output [7:0] out
wire counter_enable;
counter counter_inst (
.clk ( clk ),
.rst_n ( rst_n ),
.enable ( counter_enable ),
.count ( out )
// For simulation, use this instantiation:
NIOS_SYSTEM niosii_system_inst (
.clk_clk ( clk ), // clk.clk
.reset_reset_n ( rst_n ), // reset.reset_n
.enable_external_connection_export ( counter_enable ), // output_pio.export
.cout_export ( count )
endmodule
NIOS
int result,i;
usleep(100);
Your connection to 'cout_export' should be 'out', not count which doesn't exist in 'Counter_Top_Level_design' (only in 'counter').
As for the Nios code - it looks fine.
>>""Without FOR LOOP, how should i run the counter module.""
Without knowing what you're trying to do I don't know what to suggest.
Cheers,
Alex
Sorry :)
As per your instruction i have modified the code.
How to justify counter design is working or not ?
I have attached the screenshot in that only FOR loop is increaming ,
Design FLOW :From Quartus, i want to read the counter data in NIOS through QSYS.
- Giving Enable signal as PIO output -1-bit
- Reading Counter Data as PIO INPUT -8 bit
Please go through from the starting .
This is DISABLING the counter, not enabling it. Your verilog code has an active LOW reset in the counter module.
Cheers,
Alex
Are you expecting too much from printf? It's a VERY slow function and I can quite imagine 1000's of clock cycles happening between each of your IORD instructions.
Cheers,
Alex
I am stuck in this task for Past one week. Please tell me the Solution how to sort it out., as i am New to Altera Quartus.
Any Memories blaock will work it out like FIFO, SDRAM etc.
