How to set unused pins
How about the default settings about unused pins?
I want to set them to drive high, low or high-z.
How can I do that in assignment editor or anywhere?
thx
Assignments Menu->Settings
Select The "Device" category
Click "Device and Pin options"
Select the Unused Pins Tab on the "Device and Pin options" window
Then select the option you want as default from the pull down menu!
Bit long winded but there you go :)
