Hi
I'm pretty new in the FPGA world. I want to use ADC pins that the MAX10 so to configure such pins I used Platform Designer (Qsys). Now I need to built a simple VHDL code to create the block but I don't know how. I know that I can use schematic file and import the symbol from qsys but I want to learn how to use link qsys with VHDL. I already configure my pins and everything
链接已复制
and how do I see that instantiation template?? because when I click on HDL generates, it shows me this
At the end, I was able to find how to call the instantiation into my Top level entity. Thank you!
As we do not receive any response from you on the previous question/reply/answer that we have provided. Please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
