16848 Discussions
How we can run batch file after compilation any quartus project in quartus automatically?
NTars
I have one batch file that extract all the warnings lines from report file. After compilation process, we have all report files in our quartus directory. So, i want to run this batch file automatically after compilation process in quartus prime software.
Has anyone any idea on this?
NTars
Hi all,
I got one solution on this instead of using batch file.
I have designed one TCL script file which is executed after compilation has been done.
These are the steps to execute any TCL script file after Quartus compilation.
Steps :
  1.    Add your .tcl file to your project directory which you want to execute.
  2.    Add following command to .qsf file which can run tcl file after compilation process.
  •  set_global_assignment -name POST_FLOW_SCRIPT_FILE "quartus_sh:<tcl_file_name>.tcl"
      3.    Compile your project.
RichardTanSY_Intel
Hi, apologize for the delay. Would like to know whether you are able to run the batch file after compilation? Do you need further help?
NTars
No. Still not getting any solution on this.
Do you have any solution?
Thanks in advance.
NTars
Hi all,
Steps :
